Honeywell 8 Zone Intruder Alarm Problem (Hw8Mk)
What's the old phrase Jack of all trades master of none?
I can't do gas because its illegal,but general DIY etc,piece of piss
Change hall way pir setting to entry instead of intruder I assume you have changed a setting
Be honest have you entered the programming made a change and forgot what you did?
Hello Al-Yeti,
I entered the Engineer's Mode and set the delays for exiting and entering.
I did not change the Zone Entry/Exit setting.
I will do that as suggested.
I hopefully after the help received here will not get the setting fault at Zone 5 when exiting.
What I meant was is zone 5 attribute set as intruder ie alarm or is it set as an timed? , it needs to be timed type I think
Default would be intruder but setting to timed might work for you
The landing detector is seeing you in the hall then. It either needs to be on the entry route, masked or moved
So it did :)
