Steveheeb Posted March 1, 2014 Posted March 1, 2014 Hello, I have a bit of a weird situation following a power-off & resetting of a Veritas 8 system. Replacing the battery and resetting the system by multiple means has not made any difference. Nothing has been altered to the wiring or to the system that was working well until the power-off, so I can't figure out what else to try... The system seems to be working perfectly well, excepted that whenever any of the PIR detector is activated, whether the alarm is set or not, a tamper signal is triggered. Signals of tampering do not appear otherwise. Performing a walk testing on any of the detectors gives the same result: panel bleeping 9 times (instead of the zone number) and a code 1 fault (bell tamper, including global system tamper). What could be going on? If it was a real tamper fault, why is it only happening when any of the PIRs is activated? Thanks for any suggestion, Steve
ChrisMurphy Posted March 1, 2014 Posted March 1, 2014 cos it is wired as doel but default programming is n/c misc options 03 turn on 2 and 3 30 years of experience, ssaib approved family business. We have a very long list of clients that we are very proud chose to use us. We have never bought out any other company or forced anyone to use us. All of our customers are free to leave us whenever they wish, yet very few ever have. This is down to the fact that we always put our best into every job. http://alarmguard.co.uk
Steveheeb Posted March 2, 2014 Author Posted March 2, 2014 cos it is wired as doel but default programming is n/c misc options 03 turn on 2 and 3 Fantastic, that was it!!! Thank you so much! Steve
ChrisMurphy Posted March 2, 2014 Posted March 2, 2014 Strongly recommend a pro looks thru it if you did not know that, without been rude Just that there could be other issues that compromise your security. 30 years of experience, ssaib approved family business. We have a very long list of clients that we are very proud chose to use us. We have never bought out any other company or forced anyone to use us. All of our customers are free to leave us whenever they wish, yet very few ever have. This is down to the fact that we always put our best into every job. http://alarmguard.co.uk
