Obtain Engineer Code
Gemini
Haha, I am not doing it all together, but a bit every so often. The Landlord has always thought that the code can be used to disable the system, so keeps it protected.
Since when did an engineer code disable the system?
when it's unset,your lads wouldn't know that as they don't know the code..
It doesn't, but they think/thought that it does.
You must have too much time on your hands, if you're going through with guess work
Ever thought of getting a girlfriend to play about with
I was going to say, 'are there no pubs round your way?', but equally valid...
Correct. Customer doesn't have the manager code either.
you can't let go of the clamping ethos can you...
