Guest tivocrazy Posted September 20, 2004 Posted September 20, 2004 I am due to replace a ADE ultimate panel, but want to retain all the passives etc. Is the Karisma panel compatible with the existing ID chips and are there any other panels that would be compatible with the ID chips. Thanks
Guest IM_Alarms Posted September 20, 2004 Posted September 20, 2004 Basically, any panel with an iD variant is usable. A lot of manufacturers support iD and it should be a staight swop for the panel. Did you install it first time round?
Guest tivocrazy Posted September 20, 2004 Posted September 20, 2004 Thanks for your reply. The alarm was was originally installed by another company - but I do have the installation manual and Engineers code for it.
Guest tivocrazy Posted September 21, 2004 Posted September 21, 2004 If I did go for say the Texecom - would this definately be compatible with the exiting ID chips fitted in the sensors.
breff Posted September 21, 2004 Posted September 21, 2004 if u went for the texecom premier you would have to use their 60 zone id expander. it will work with the existing id biscuits. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
j.paul Posted September 21, 2004 Posted September 21, 2004 I am due to replace a ADE ultimate panel ADE now do a replacement for the Ultimate panel called the Captive8-256 You can get more info from the here: Captiv 8-256 info PS They are going to stop making the Karisma panel when they have used all the parts up (that will be replaced by the smaller Captive panel out in the next few weeks) There are no stupid questions, but there are a LOT of inquisitive idiots.
Guest Guest Posted September 21, 2004 Posted September 21, 2004 If you can buy one you could also look at the Castle-Caretech meridian range.
