System recommendations
Guest DRW
Hi,
Newbie here, so be gentle. We're in the process of renovating a 200-year-old house, including complete rewiring. Naturally we'll need a decent security system, and we're currently deciding between a pro job and something we can do ourselves.
Can any of you guys can recommend a make of system and suitable supplier? It's a four-bedroom house in North Lincs. We were going to go with a control panel in the attic plus keypads at the front and back doors. But then I discovered this site...
So if we go with a pretty standard set-up, what's desirable for future expansion? Is it worth adding stuff like fire and smoke detectors? I've read about voice diallers that will phone my mobile if the alarm is sounded
Have you done alarms before?
23893[/snapback]
Not me, but my g/f's dad (who's helping with the project) has done a few
Keypads at all entry points, internal speakers at all entry points, contacts on all doors, 1 PIR per downstairs room. Upstairs PIR on landing, possibly PIR in main bedroom (protect the wifes jewellery). Also if any bedrooms have flat roofs/conservatories below their windows PIR in them as well.
You could go for shock sensors on windows but most people dont.
Always advisable to put at least one smoke detector per floor.
Control panel location, somewhere in the centre of the house if possible keeps cable runs easier. Understairs cupboard, airing cupboard etc. Run a phone line to the panel and it gives you the option of dialler etc.
Live bell front of house, Live or Dummy at rear.
Hope this helps.
PS Use 8 core alarm cable for everything and use a panel with enough zones to wire 1 detector per zone.
Glenn
I agree, go the Professional route. you will get a much better job done clearly and it you will regret doing it yourself later anyway.
If a job is worth doing etc......... :)
Thanks for your answers, guys. Very useful.
I'll try to get hold of some local professionals to give quotes. I've noticed support on here for certain brands (eg Galaxy), so would you recommend one panel in particular? I'm not too fussy about price as long as it's expandable, has nice-looking keypads and won't need servicing every few months.
If we do go down the self-fitting route (my girlfriend's dad does know what he's doing
DRW. how many sensors will you need using the rules set by breff. Yes your right ADE Pyronix and Lyntek are naff they are more for diy/low end trade .
Dave Oxendale
York based security systems engineer.
Hi,
Under Breff's rules, this is what I'm planning:
- two keypads/entry points
- four door contacts
- four downstairs PIRs
- two upstairs PIRs
- don't know about shock sensors
- three smoke detectors (one on each floor)
- control panel will have to be in the attic (where we currently have no floor...)
- live bell at rear of house (it's Listed)
- phone dialler.
I also want to leave expansion for ground floor extension and conservatory. We'll be building garaging away from the house, but I think we'll go with a separate system.
Hi,
- two upstairs PIRs
- phone dialler.
23994[/snapback]
Rather than install a new seperate system at a later date, why don't you run a cable now and then if you've used a panel (for example Texecom Premier 48, Galaxy 18 upwards) which has more than one area/group/ward then you can program the system as though the garage were a totally seperate alarm but without the cost, extra work etc
Hope this helps.
Glenn
23904[/snapback]
