scanman Posted March 15, 2014 Posted March 15, 2014 Hi, I want to change an external bellbox for an elderly neighbour, it is one of those huge blue ones about 6 to 8 inches deep with a blue strobe in the middle which were quite popular about 20 years ago! The alarm panel is an aged but reliable Scantronic 9452 but the blue bellbox is falling apart. I have bought a Texecom Odyssey 3E and want to replace it, however we don't have the Engineer code as the relative stopped the £100 a year service contract several years ago (not surprised) and the ex-service company will not give the Engineer code to him. Anyway, I am electrically competent having done house rewires and fitted 3 alarms 15 years ago (Scantronic 9448 ones), my question regarding changing the bellbox is: 1) Is it best to pull the 3A spur fuse, disconnect the backup battery, put some ear defenders on and change the bellbox or...... 2) Put on some ear defenders and just change the bellbox with the panel still powered. Obviously I know about not shorting cables together. If 2 is the best way, is there a best order to connecting the new 3E bellbox back up? Finally, a separate question, in my house I have had to move a radiator during a kitchen refit and I have a PIR (Pyronix Quad, 15 years old), I assume it is best to relocate the PIR! Many thanks
matthew.brough Posted March 15, 2014 Posted March 15, 2014 however we don't have the Engineer code as the relative stopped the £100 a year service contract several years ago (not surprised) and the ex-service company will not give the Engineer code to him. Doesn't seem that unreasonable? My home brodband costs me £720 per year so £100 for an alarm seems small change in comparison. and the ex-service company will not give the Engineer code to him. Quite right too. This is confidential to the alarm company. Before answering your other part of the thread. Do you know if the alarm is set that tamper alarms are engineer reset only or if they are an customer reset? I assume customer reset but I just wanted to check you are sure on this point otherwise the minute you tamper it, it is going to need the engineer code you haven't got to reset it. www.securitywarehouse.co.uk/catalog/
goncall Posted March 15, 2014 Posted March 15, 2014 Doesn't seem that unreasonable? My home brodband costs me £720 per year so £100 for an alarm seems small change in comparison. matt,look at join date and posts
datadiffusion Posted March 15, 2014 Posted March 15, 2014 The manual for this system fits on the back of an envelope (literally) so I don't think engineer only resets are even an option. I stand to be corrected if needed though! matt,look at join date and posts huh? So, I've decided to take my work back underground.... to stop it falling into the wrong hands
matthew.brough Posted March 15, 2014 Posted March 15, 2014 The manual for this system fits on the back of an envelope (literally) so I don't think engineer only resets are even an option. I stand to be corrected if needed though! huh? Nope you are indeed correct. Just looked at the 'very indepth' manual. Alarms can be eng reset but not tampers so that's not an issue then 1) Is it best to pull the 3A spur fuse, disconnect the backup battery, put some ear defenders on and change the bellbox or...... www.securitywarehouse.co.uk/catalog/
datadiffusion Posted March 15, 2014 Posted March 15, 2014 I've got a 9448 on service (original 3 zone like this) and the 'manual' is literally a slip of 1/3 A3 card.... Ah those were the days! So, I've decided to take my work back underground.... to stop it falling into the wrong hands
scanman Posted March 15, 2014 Author Posted March 15, 2014 Men Thanks for replying but can anyone answer my query, I guess reading between the lines either 1 or 2 will work fine.....!
matthew.brough Posted March 15, 2014 Posted March 15, 2014 I answered option 1? www.securitywarehouse.co.uk/catalog/
Alarm Protection Posted March 15, 2014 Posted March 15, 2014 Switch the system of at the mains then do what you have to do. Then switch back on and it works or doesn't! !
PSE Posted March 16, 2014 Posted March 16, 2014 And you're after trade access with questions like this ?
