goncall Posted March 28, 2014 Posted March 28, 2014 Only what I saw and It didn't look good for us alarm companies tbh. I don't use texecom bells but a local has a lot up! lets hope he's hasn't got a packet of chweing gum in the next episode
datadiffusion Posted March 28, 2014 Posted March 28, 2014 Or a biro to pick open a D-lock.... So, I've decided to take my work back underground.... to stop it falling into the wrong hands
goncall Posted March 28, 2014 Posted March 28, 2014 Or a biro to pick open a D-lock.... or some of those special glasses that see the ir beams
Amps Posted March 28, 2014 Posted March 28, 2014 I don't know James but it shows the Gary builder boy up his ladder, open bell which sounds for 2 seconds and he cuts cable that disables the bell. I think texecom would go mental on this? I have never installed that bell but is the back up battery enclosed or can you just cut 4 wires that are free to cut? Truth is with most bell boxes its only one wire you need to cut. Bring back the double skinned bell box i say! I remember years ago one high street chain having a double skinned metal bell box that if drilled would create a short between the skins which would then tamper. There was also a pendulum type of switch inside to detect any movement. And was fixed with rawl bolts! Try disabling that fecker!!!
matthew.brough Posted March 28, 2014 Posted March 28, 2014 Truth is with most bell boxes its only one wire you need to cut. The red one? www.securitywarehouse.co.uk/catalog/
goncall Posted March 28, 2014 Posted March 28, 2014 Truth is with most bell boxes its only one wire you need to cut. Bring back the double skinned bell box i say! I remember years ago one high street chain having a double skinned metal bell box that if drilled would create a short between the skins which would then tamper. There was also a pendulum type of switch inside to detect any movement. And was fixed with rawl bolts! Try disabling that fecker!!! you can still get the rapier with anti drill inner cover
matthew.brough Posted March 28, 2014 Posted March 28, 2014 you can still get the rapier with anti drill inner cover I always wondered if they called it rapier to describe it's price point . . . www.securitywarehouse.co.uk/catalog/
matthew.brough Posted March 28, 2014 Posted March 28, 2014 Good idea, just to be sure like www.securitywarehouse.co.uk/catalog/
goncall Posted March 28, 2014 Posted March 28, 2014 I always wondered if they called it rapier to describe it's price point . . . rape your ears I reckon,they are loud..
