GalaxyGuy Posted June 16, 2017 Posted June 16, 2017 I tried changing the address, but the menu just shows the address allowing it to be disabled or enabled, not changed. If you disable, it still consumes the address and the hard wired Rio cannot enumerate on the bus. At least if you add in the order I mentioned, then it will work. I'm not sure why alpha isn't working for you. Did you power cycle the portal after changing the jumpers? I can add devices in alpha and V2. The serial number of the IR8 is different under each protocol. I was using a V1.08 portal, so will try a V3 when I get a minute. Quote
