Redcare Secure Line Fault
whizzer
Had to connect to a galaxy 48 today but needed to use a relay. is there a way to connect to a galaxy or is using a relay the only way ?
On a MK3 secure, can you use 485 on a g2?
I know on a demention you can connect via serial, 485 or dialcapture (if needed)
If its a mk3 secure,  you can connect a 1k resistor to a zone. OP1 then needs enabling in the secure unit, to "galaxy mode"  (done via its browser)
You tube has a few vid's from Redcare
