Paul Lewinski Posted April 10, 2014 Posted April 10, 2014 hello please help! I had installed a galaxy g2 and I am having difficulty with it (it is not connected to a monitoring agency, it is standalone). I was playing with it (trying to learn it) and I triggered the intruder alarm and then tampered with the pir so I now have 2 error messages on the keypad.(intruder and tamper). I use my 4 digit user passcode and press '>' and I can scroll through the errors. I cannot clear them. When I scroll to the intruder message I get 'reset required', when I scroll to the tamper message I get 'ent to continue' when I press 'ent' I get 'engineers code required' I have a 6 digit engineer code and when I type that in I get 'Additional code required'. What is this code? as I only have 2 codes (4 digit user and 6 digit engineers) I also have a keytag that I saw the installer using but I have tried swiping it and it just beep and still doesn't allow me to enter into engineers mode. I would ask my friend who is the installer but he is away and presently the system is not allowing me to set the alarm when the faults are showing. Can you please help me clear these messages, as I do not even seem to be able to get into engineers mode. Thanks Paul
matthew.brough Posted April 10, 2014 Posted April 10, 2014 You need to enable engineer access via your user code then it will let you in. You can turn off this requirement once in engineers www.securitywarehouse.co.uk/catalog/
GalaxyGuy Posted April 10, 2014 Posted April 10, 2014 You will need to enable engineer access using menu option 48 whilst logged in as the master user. After enabling access, the engineer code will work.
matthew.brough Posted April 10, 2014 Posted April 10, 2014 Nice echo www.securitywarehouse.co.uk/catalog/
Paul Lewinski Posted April 10, 2014 Author Posted April 10, 2014 thanks how do I enable this please? actually I have been looking for an option 48 but cant find it? I type the 4 digit user code then press > what do I press next to find option 48 pls?
Paul Lewinski Posted April 10, 2014 Author Posted April 10, 2014 he set it up fine, it was me that messed it up.
Ronnie Posted April 10, 2014 Posted April 10, 2014 he set it up fine, it was me that messed it up. you miss the point, where is your support when you need it regardless of the cause.
Paul Lewinski Posted April 10, 2014 Author Posted April 10, 2014 point taken. I want to learn it myself though and not rely on him anyway, that's why I'm asking, thanks.
matthew.brough Posted April 10, 2014 Posted April 10, 2014 thanks how do I enable this please? actually I have been looking for an option 48 but cant find it? I type the 4 digit user code then press > what do I press next to find option 48 pls? Code ENT 48 you miss the point, where is your support when you need it regardless of the cause. Remember. Give a paw. www.securitywarehouse.co.uk/catalog/
