Texecom Premier Elite 12-W Problems
stormin
Hi everyone ,,,,hope some one can help ..
I am a napit approved Part P electrician who now fits alarms to help supplement my income .
I have been fitting alarms on and off for over a year now and I had no idea how much knowledge you guys need to be able to fit alarms .
So Hats off to you guys .
I bought aTexecom 12-w panel with RMK new in box .
1 Richochet pir -w, 1 shock/door impaq-w.
4 hard wired zones.
the 4 hard wired zones all fitted with resistors(no zones used ) ..
tamp for these zone fitted resistor .
bell/tamp fitted resistor .No bell box fitted Yet ).Bell-Tamper
I am using Ricoshet zones 9 for impaq/door and zone 10 for pir .
I put the panel tamper on hold so it would not keep giving alarm.
When I power up panel it goes into alarm .
rkp shows these messages .
System Alert
zone 1234 in tamper
bell tamper
Call ARC Center.
Area needs reset.
when I put enginer code in it stop alarm but Service light comes on..
Any help really would be appreciated
Zones still prog'd as double pole.
Digi prog needed.
Take it you dont have your lappy connected using udl.
Shouldn't the bell tamp just be a link. Plus what resistors have you used
Hi yes it should be 3.2 k resistors which were sent with panel...but with help from you guys it got sorted ,,thanks
Digi prog needed.
Hi  again,,,Yes  ,,zones were dp as you suggested..
I have since downloaded wintex 6.2 and wintex richochet monitor .
from wintex monitor
I now have zone 9 ent/exit on impq shock .
I have now zone 10 pir on guard ..
once I have set richoshet zones and devices in eng utils  How can I save the settng to the wintex
I have seen in wintex send page to panel ,,,do i set zones in in wintex firsy or do I ask panel to send a page ?.
Thank you both for taking the time to answer .
Because speaking for myself  it would take me and other in the same situation as myself weeks to phathom some of these
settings out ..thanks again.
Zones do not need to be linked out.
You have to program the system using the Engineering Menus.
Bell tamper is a 0V link.
Hi thanks for getting back to me ..
bell tamper now not showin due to neg to tmps link.
I am not sure how to program the system from eng/util to link them out ..
Many thanks to you
Your posts makes no sense. I'm assuming you mean you have a bell tamper and aux tamper showing on the panel and want to know how to disable them both through the keypad?
If it makes no sense no need to continue ,,,thanks for your help.
