Dvr With Set Input
topgunn
Can anyone recommend or know of a dvr that has a relay to accept a set signal from an alarm which will then trigger motion to an email address when set?
How would a relay trigger a motion alarm? Are you not simply trying to get an email every time an alarm is set or unset?
Motion to send an email simple. Want only when the intruder alarm is set.
Soo basically, an output to trigger an input on the dvr to know its set.
I have only come across this on an adpro but expensive and ott. After your standard average 8ch dvr with a set input.
I was more looking for a figure in pounds shillings and pence? Average DVR isn't a currency I know. In my world an average 8 way DVR would be around £850 which might not be the same average you are looking to spend, hence the question.
That rules out UTCs offering. I have a cheaper DVR connected up and I'm sure you can use the input as an arm/disarm as we looked at it for cheaper CCTV monitoring. Just let me check before I commit and good news is cost wise it's 1/2 your budgeted price :)
