paul44 Posted April 20, 2014 Posted April 20, 2014 Hi all, im looking to buy some test kit for doing minor works for fused spurs etc. Just wondering what other engineers are using as they are bloody expensive and most do stuff that only a spark would need.
Rulland Posted April 20, 2014 Posted April 20, 2014 Get one that does all the required tests as per BS7671 for circuits you have added/modified. Some testers have additional features such as 'auto rcd' and 'ramp' etc, but if it's for just basic use then a basic 17th edition multifunction or equivalent would suffice.
PSE Posted April 20, 2014 Posted April 20, 2014 I use the Megger MFT 1720, Get my certificates books direct from the NICEIC website, they are good quality ones
Rulland Posted April 21, 2014 Posted April 21, 2014 I do my certs using the NICEIC online facility, uses drop down boxes to select everything, and it's only £1 a pop, informs building control etc, and sends cert directly to client via email if you want.
PSE Posted April 21, 2014 Posted April 21, 2014 Get a book of 50 or 100, can't remember from NICEIC for £15.00'ish
matthew.brough Posted April 21, 2014 Posted April 21, 2014 Not like alarm certs then . . . www.securitywarehouse.co.uk/catalog/
Paul P Posted April 21, 2014 Posted April 21, 2014 On 21/04/2014 at 10:47, PSE said: We can only wish, ..... Cert charges are a farse These are free to use, you can also make your own like you do for alarms The sample ones in the regs are not copy right I think you will find. http://electrical.theiet.org/wiring-regulations/forms/2008-amd1-forms.cfm Trade Member
paul44 Posted April 21, 2014 Author Posted April 21, 2014 Ive found a meter, metrel ML3000 that seems to fit the bill. Just over £400, bargain, might buy 2!
MrHappy Posted April 21, 2014 Posted April 21, 2014 Metrel are a bit lucky dip with readings, leads are short lived too. whe are intending to replace our instruments with Meggar multifunction testers at somepoint Mr Veritas God
