Some More Stupid Questions..
zerozero
I'm sure most people would just try this stuff instead of asking but I don't want to end up in the name and shame section later  so just double checking :)
1. I am planning to run a Texecom Exodus Fire alarm and an AMQD PIR off of Keypad 1 zones and they both need 12v power. Is there any reason why I can't/shouldn't simply use the +12v/0v off of the network terminals inside the keypad? .. I'm sure not, but just checking..
2. On the AMQD anti mask detectors, alongside the normal +12v/0V/T-EOL pair and test terminals there is a connector SET  that I don't really understand. In the book it says
SET: 12V/No connection: Detector is in the Standby/unset mode
0V: Detector is in the Alert/set mode
But surely I want it to be set / unset by the panel? is this used for some diagnostic function normally and I should usually leave it with no connection or is there something that I'm missing.
cheers guys
No
This is to let the detector know that the system is armed.
This could be for a few reasons, including disabling LED's.
There is an LED Control option in the programming for a reason.
1. 12v is 12v
Don't forget Grade 3 systems require LEDs off except when in walk test .
Except on your systems?
