bellman Posted September 22, 2004 Posted September 22, 2004 It's the sad techie life I lead that does it Bri How did you get on with the max by the way? Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
breff Posted September 22, 2004 Posted September 22, 2004 Bellman, you have proved you truly are a genius, I've never thought of that one. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Brian c Posted September 22, 2004 Posted September 22, 2004 some numpty on the original install had linked a set output to the max rather than linking the max to the output, making only operational when set! It was my fault also, for taking so long to notice I was the 4th engineer to the same fault, though! If you don't know......ask.
bellman Posted September 22, 2004 Posted September 22, 2004 Bellman, you have proved you truly are a genius, I've never thought of that one. 24287[/snapback] I'm so flattered Just a little application of the K.I.S.S. principle (Keep It Simple Stupid) Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
bellman Posted September 22, 2004 Posted September 22, 2004 I was the 4th engineer to the same fault, though! 24291[/snapback] But you fixed it....... Pats on the back all round Bri... :moe_thumbs_up: Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
