Vcl Domes With Maxcom16 On A Dm?
connor2425
Hi, we have recently changed out a system running VCL domes and a maxcom 16.
We have put in a dm with keyboard, everything is run up the coax.
What would be needed to drive these domes on this dvr?
cheers
Can VCL domes do pelco p or d? If so get a rx10x from BBV
In fact I just looked and the rx10x can do VCL 485 anyway
i thought vcl coax was done thru dm itself not serial
07475071344
