wards
Lectrician
Someone please give a quick talk on wards......
I have fitted several menvier TS panels (as a spark). I have used the wards to do part sets.
Can wards be assigned to keypads. Meaning......I have a seperate garage with no alarm, my house is alarmed. I wanted to run an armoured to the garage, feeding a keypad, and run 2 zones from the pad in the garage. (menvier system). In my mind, i would prefer the garage to stay set all the time, until you unset it from ITS keypad. When you set and unset the house, I would prefer the garage to remain armed. (and vica versa).
Is the menvier panel capable of this (I dont think so), if not, what panel is??
Email : martin@askthetrades.co.uk
Which Menvier panel have you got installed in the house?
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
24189[/snapback]
TS790+ ready to fit in place of a Veritas R8
I know if its a TS900 it cant but you can use code sets for different wards. I think the 790 is the same.
Incidentally its no problem with the Texecom Premier and theres 2 zones in the keypad
Has the texecom premier got good reviews - you lot hate them dont you??
How many cores from panel to pad for that panel??
Yup, hate them (but not as much as the veritas)
go menvier......
regards
Bellman
Wards are a doddle on the menvier, don't listen to the texecom cheepie brigade....
Buy Cheep, buy twice.......
It doesn't appear that you can assign a keypad to a ward on the 790 (I may be wrong). However, you can assign a code to a group and it will operate similar to your requirements.
1 code for the house, 1 code for the garage
If you don't know......ask.
