Steven_W Posted May 6, 2014 Posted May 6, 2014 At DVR end looking for a tidy solution for CAT5s from cams with baluns on to go into to in turn go to DVR for neater terminations. Baluns are packed so tight on the back of DVRs & it looks terrible! ...
PSE Posted May 6, 2014 Posted May 6, 2014 Terminate the cat5 and baluns into a box, then drop out with RG59 into the DVR
matthew.brough Posted May 6, 2014 Posted May 6, 2014 That's what I thought www.securitywarehouse.co.uk/catalog/
PSE Posted May 6, 2014 Posted May 6, 2014 Cat5 is far too fragile to terminate straight into the back of the DVR, Plus it looks $hite and el-cheapo install
petrolhead Posted May 6, 2014 Posted May 6, 2014 I usually use a full size elmdene, nice big box to fit he baluns ina nd plenty room for fuses.
Alpat Systems Posted May 7, 2014 Posted May 7, 2014 Rack Mount DVR and Rack Mount Balun As above There's lots of off the shelf 16 port choices available http://geniecctv.com/wp-content/uploads/2013/03/GTH016-Datasheet.pdf http://www.dynamic-cctv.com/product/dtv-16chbalun/ or build your own up using rack mount chassis's http://muxlab.com/products/category/cctv/rackmount-transceiver-chassis
