Scantronic I-On 30
Hi all, has anybody had any trouble setting partitions with the i-on hybrid ?
my problem is this, i have a full set, a part set (b) and a garage set ©.
i am aware of having to program each rkp to set a,b,c which i have, i have (i think) programmed the 2 rkp's to set partition 2 with the "c" key and programmed the selected zones (garage detection) "yes" in both partition 1 and 2.
when i set the system ( C ) it sets but nothing seems to be set, i can walk around the garage and open doors i thought were set.
i have done similar with set "b" and that is ok although they are all in partition 1.
any ideas ?
I have a system where the garage (remote) is a partition of it own and set independently (has its own rkp, or user unsets as he goes out the back door with its own RKP) , no issues (other than the bloody ventcroft contacts, using knight now). That's all fine. However, on mine no zone is in more than one partition, because the buy didn't want the garage being autoset if his wife went out etc... and didn't realise he was in the garage.
I should add that I have other i-on systems (40s or 50's mind) with shared zones, although these are 24 hr or fire zones, that definitely activate!
