Prodigious Posted May 12, 2014 Posted May 12, 2014 gen question on the texecom wireless ricochet product. Ive fitted well over 100 texcom panels but only done about 4 of the wireless systems and installed one 14 months ago and it has been working fine but has developed a fault, when arrived at the propety all the zones were active, i programed all the zones to then unused then put them back on and now all zones are secure but every single zone does not pick up anything on a walk test or in normal use. ive even tryed relearning a device but it wont even relearn. Has anyone come across this before? Im thinking the receiver needs replacing Thrones
sixwheeledbeast Posted May 12, 2014 Posted May 12, 2014 Need to post up:- Panel Firmware Version Ricochet Expander Version List of devices fitted to the system including type and which mode.
Adi Posted May 12, 2014 Posted May 12, 2014 you need to delete before you can relearn. I really can't be ar**** with it anymore.
Prodigious Posted May 12, 2014 Author Posted May 12, 2014 you need to delete before you can relearn. i did Thrones
