Wintex Will Not Connect To Texecom Premier 88
Hi there i have been trying at this for hours now and for some reason can not get it to work. I have followed all of the instructions perfectly but am still unable to establish a connection between Wintex and the system.
Some information is being communicated between the two because the Wintex manages to retrieve the device serial number.
Any help would be greatly appreciated.
Thanks
Some info on how you are trying to connect would be useful? PSTN/Webway etc
Screenshots of settings would also be useful
Apologies, I am trying to connect via USB and I have already identified which COM port it is.
If the UDL is changed, then upon connection it complains that it is incorrect (further confirming that communication takes place).
Having tried using the account with all zoned configured to connect with no success, I decided to restart from scratch with the most basic default settings, as described in the manual, specifying no information other than the COM port and account ref.
The message I keep facing is "Connection with Control Panel could not be established - Please check settings and try again!"
This appears shortly after "Status: Requesting access with panel..."
 Had this one i was accesung mine was due to a school boy error selecting a premIor panel when it was the elite model. Double check software version of the control panel.
Trade Member
