Setting Up Texecom 24 Areas / Part Setting
Hi ive installed a texecom 24 alarm, with 24 zones and 4 keypads, some zones and one keypad are in an outbuilding which I may wish to set separately to the main house, can someone explain how to set this up, I don't need every keystroke / programming just the basic principle.
Am I correct in thinking this would be different to a part set?
Many Thanks
Andy
Yes
House Area A.
You can still then have a 'part arm' for night set for example.
Outbuildings Area B
Keep the keypads separate to each area, keeps it simple then. Code for the house assigned to area A. Outbuildings area B.
yes its an elite
Many Thanks for your help and sharing you knowledge :)
One quick not so simple complication
Can I set up the house door keypad so when you arm on leaving the house it sets areas a & b and when you return and disarm it just unsets area a? or am I complicating things?
You gave me the clue already, guess I can set using "area" on keypad set up for A&B and unset with an area a user code just to unset area a
Also look at the local arm and disarm options.
