Fearghal Posted May 24, 2014 Posted May 24, 2014 I have just recently moved into a new house with a Aritech cs350 alarm system installed. The landlord does not know the code(s) to the system. It's also flashing "low battery". Can anyone suggest how I could reset the code for the system so that I can use it myself? Is there a helpdesk or something I can call? Also if the battery dies will the alarm start going off? I won't have the code to stop this if it does! Thanks
SouthernBrad Posted May 24, 2014 Posted May 24, 2014 The best thing to do would be to contact the company that installed it and get it serviced along with a new battery.Low battery sounds like it's been neglected for quite some time and could do with a good check over before you use it incase it has faults and id forever false alarming.Explain to the surveyor you wan't to delete the old codes and use new ones.
datadiffusion Posted May 24, 2014 Posted May 24, 2014 Or ask the landlord to! So, I've decided to take my work back underground.... to stop it falling into the wrong hands
norman Posted May 24, 2014 Posted May 24, 2014 Depends on the lease... Nothing is foolproof to a sufficiently talented fool.
