jiml Posted June 6, 2014 Posted June 6, 2014 Check the sensitivity of the detector is set to high. It should be if the pet filter is fitted.
sixwheeledbeast Posted June 6, 2014 Posted June 6, 2014 I echo dd's comments Facing the front door is not ideal for a PIR, walking towards a detector has less detection beams than across. I would recommend a front door contact for starting and terminating the timer (final set). Check the settings inside the detector.
