Richfl Posted May 31, 2014 Posted May 31, 2014 Dear forum, I am desperate for some help with wiring for my new alarm system bell box. After many failed attempts and a ringing head my problem is: - I have an infinite prime alarm with a wireless sounder module (inf-wsm) with the following four terminals in: S T - + - I am trying to connect to a ADE Reson 8 bell box which has FIVE TERMINAL points: Rtn - Hold off + Hold off - Trig - STB - I cannot get the configuration of the wiring correct to make it sound when the control panel sends a signal. Can anyone offer advice as to how I connect the four cables to the five terminal positions to correctly install. Many thanks Richard
al-yeti Posted May 31, 2014 Posted May 31, 2014 How about - to - hold off + to + hold off -rtn to t (tamper switch return) I assuming trg and stb are bell and strobe just join both to s Although I thought there should be another output to seperate them this will still work as both should be negative triggers meaning if you have more than one terminal for the strobe connect to the - minus one Didn't look up the panel but someone can confirm
