djlay Posted June 2, 2014 Posted June 2, 2014 Hi Folks, I realise this question may be outside of the scope of the public forum but any clues would be much appreciated. I'm having a bit of trouble with a galaxy G2-44 endstation that is installed in my friends shop. Until recently it was serviced by a local company however they are no longer in the alarm trade and are unable to help. The system has been out of use for sometime and no one knows any of the codes. I've tried to default the system by removing connections to 1001, etc, etc. I left it dead for 10 mins and when powering up it will not accept the default user/engineer codes. I'm not actually sure if it has successfully defaulted, or if it has non-standard default codes (hard coded) in the panel by the installer. Any help would be much appreciated. Dan
james.wilson Posted June 2, 2014 Posted June 2, 2014 we cant discuss defaulting in the public area. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
morph Posted June 2, 2014 Posted June 2, 2014 You need to get someone in who knows what they are doing, a local company should be able to help as a galaxy is a well used panel.
djlay Posted June 2, 2014 Author Posted June 2, 2014 Ok no problems. I've had a look at what's required to become a trade member on these forums and I seem to qualify so will proceed with application. I've programmed and installed Galaxy and Aritech systems in the past but have never come across the need to default. Dan
james.wilson Posted June 2, 2014 Posted June 2, 2014 if your trade then fine. please dont try to blag it. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
matthew.brough Posted June 2, 2014 Posted June 2, 2014 and Aritech systems in the past but have never come across the need to default. Dan ATS expert? www.securitywarehouse.co.uk/catalog/
djlay Posted June 2, 2014 Author Posted June 2, 2014 Don't worry James, I'm legit. See you on the other side.. I have installed a few 9003 systems way back when. I did actually like them, they had a nice feature where you could create a split system. No i've not installed any of the newer ATS ge/aritech panels but they look pro.
matthew.brough Posted June 2, 2014 Posted June 2, 2014 No i've not installed any of the newer ATS ge/aritech panels but they look pro. They are, and rock hard www.securitywarehouse.co.uk/catalog/
djlay Posted June 2, 2014 Author Posted June 2, 2014 I wouldn't mind having a play with one. Are they effectively an updated version of the old Aritech panels or are they completely different?
matthew.brough Posted June 2, 2014 Posted June 2, 2014 Lol Apart from 4k7 resistors there is little similarity. www.securitywarehouse.co.uk/catalog/
