September 23, 200422 yr comment_24539 I was in possession of the previous owners user code on my Optima XL4 alarm system, and using the operating instructions I changed the code. Everything seemed fine until I attempted to set the alarm and found that the new code I had entered did not work. I entered the old code and found that this also didn't work. I have tried several combinations around the new code in case I inadvertently pressed the wrong digit whilst changing the code - no success. Any suggestions please Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3683-optima-xl4/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 23, 200422 yr comment_24540 Try 0123 or 1234 first and let us know if either of those work. ........................................................ Dave Partridge (Romec Service Engineer) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3683-optima-xl4/#findComment-24540 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 24, 200422 yr comment_24593 Try 0123 or 1234 first and let us know if either of those work. 24540[/snapback] Sorry - doesn't work either Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3683-optima-xl4/#findComment-24593 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 24, 200422 yr comment_24595 Try 0123 or 1234 first and let us know if either of those work. 24540[/snapback] Sorry - doesn't work either 24593[/snapback] Contacted a local supplier who was very helpful - told me how to reset system to factory settings (0123) & have since changed code successfully. Thanks for all your help. Regards Jim H Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3683-optima-xl4/#findComment-24595 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 24, 200422 yr comment_24597 Did he also tell you how to check the if programming was ok for your install or how to change it? If you don't know......ask. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/3683-optima-xl4/#findComment-24597 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
