9651 Possible Problem?
djrock
Hello, I got a new/old stock 9651en for a friend, in the log around about the start there is a EEPROM fail then there are several other entries like tampers, pa zone open. Then there is entries that I know I have caused like system startup, lid tamper, engineer on site.
Roughly where I started generating entries in the log there has not been another mention of EEPROM fail.
Is it normal to have EEPROM fail at the very start of the log?
Thankyou
Djrock
I have seen that on startup not sure why, but it shouldn't occur again once your setup and running, It may occur if you default the system aswell
Hi, ok, that's good it's normal.
Thankyou
Djrock
