craigstory Posted June 8, 2014 Posted June 8, 2014 my friend had a system installed by a company a few years ago, but recently seems to be having problems with the camera's where it seems to ghost some of the picture onto another camera, it only seemd to do it on 2 cameras so tryed changing the PSU but still seemed to be the same it only happens on 2 camera's tried swapping onto different channels at the DVR but still the same. camera one has white lines running accross it and camera 2 seems to have the white lines running accross but you can kind of see the picture from camera one on it any idea's? thanks
james.wilson Posted June 8, 2014 Posted June 8, 2014 What equipment, have you tested the cameras on a test monitor? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Serg Posted June 8, 2014 Posted June 8, 2014 any idea's? Sure, it is so called ground loop issue. Very common prob in cctv systems here.
craigstory Posted June 8, 2014 Author Posted June 8, 2014 What would the cause of the issue be and what would the solution be? Camera is fine if it's plugged direct into DVR with fly leads
matthew.brough Posted June 8, 2014 Posted June 8, 2014 what would the solution be? To call someone who knew what they were doing? www.securitywarehouse.co.uk/catalog/
craigstory Posted June 8, 2014 Author Posted June 8, 2014 Just to note they all back to the same room and obtain power via a 24 camera panel psu
matthew.brough Posted June 8, 2014 Posted June 8, 2014 Camera is fine if it's plugged direct into DVR with fly leads It will be. The camera isn't the issue. www.securitywarehouse.co.uk/catalog/
craigstory Posted June 8, 2014 Author Posted June 8, 2014 To call someone who knew what they were doing? Then wouldn't this forum be a complete waste of time and it's obvious that you have too much of it anyway making pointless comments
matthew.brough Posted June 8, 2014 Posted June 8, 2014 pointless comments? The issue here is that you aren't capable of fixing it. The purpose of the DIY part of the forum is to assist diyers with DIY kit. Your issue isn't a DIY problem. www.securitywarehouse.co.uk/catalog/
