melcom st 6000
Guest doinkmilll
Guest doinkmilll
i have a melcom st 6000 system in my house and the pir in the kitchen is giving a tamper fault message on the control panel.. how can i reset this fault or remove the pir from the system so i can at least use the alarm.
any help gratefully recieved
thanks :!:
You can just undo the tamper wire from the pir and the panel and link the tamper loop on the panel
IIRC the ST6000 has a global tamper , so you could have a fault anywhere on the system , or bell circuit.If bypassing the kitchen sensor doesn't cure it, then it might be worthwhile to get in a pro.
To omit a zone enter CODE , OMIT , zone number , SET.
To reset ........enter CODE , RESET.
