Swirley84 Posted June 20, 2014 Posted June 20, 2014 Hi Thanks in advance to anyone who can help in advance. My parents have just had a toilet made under the stairs, my friend who is an electrician disconnected the old 9200 panel. I am just wondering what panel you guys would reccomend me to buy? I am aware we may need to change the PRI sensors and door magnets etc. I would like the new system to be hardwired as I beleve we can use all the existing wires? Any advise would be helpful Thanks again Eng
gsd Posted June 20, 2014 Posted June 20, 2014 Well there are plenty of options if you want an on board keypad then you can get if you want another scantronic then a 9448 would be ok or a gardtec but if you want a separate keypad (rkp) then scantronic, pyronix, honeywell galaxy, gardtec and texecom all make good stuff so use the makes from this post and look around and the pir's will be ok if they work.
Swirley84 Posted June 20, 2014 Author Posted June 20, 2014 Thanks for your reply. As the 9200 was massive it was hidden under the stairs. We want a small new modern lcd keypad, i will have a look at your suggestions, thanks. Is ebay a safe bet to purchase these kits/panels? Everything worked fine with the original system it was just the scantronic box being to big and being needed to be moved. Thanks mate
norman Posted June 20, 2014 Posted June 20, 2014 Try Security warehouse securitywarehouse.co.uk Nothing is foolproof to a sufficiently talented fool.
Swirley84 Posted June 20, 2014 Author Posted June 20, 2014 Will do could you advise a specific unit to look at?
gsd Posted June 20, 2014 Posted June 20, 2014 Ebay would be an ok place to buy alarms the 9200 was a great panel I have one in my garage I would recommend a scantronic 9651 this would be perfect for you as you want an lcd screen or even look at menvier alarms they are also very good
Swirley84 Posted June 20, 2014 Author Posted June 20, 2014 Thanks GSD, I have found the following on secuirty warehouses website.. http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&cPath=36_102_41&products_id=811 Seems decent enough and has good reviews, I will also check the Menvier alarms out as mentioned. Thanks for all the help guys.
Alarm Protection Posted June 20, 2014 Posted June 20, 2014 For a basic system with built in autodialler have a look at the Gardtec CPX. Fitted them for years. !
AlarmScot Posted June 20, 2014 Posted June 20, 2014 For a basic system with built in autodialler have a look at the Gardtec CPX. Fitted them for years. You can't go wrong with that alarm!
