Glass Break Sensors
Guest simonrob
Guest simonrob
I have recently completed an install in a local shop.
Part of the install involved providing a glass break sensor (Used IntelliSense FG-1015 units) in each bay window on either side of the front door.
There is a shutter on the inside of the front door that is remotely controlled.
When the shutter is raised, with the system set, the glass breaks are activating. This happening on both sensors. The Customer needs sensors in the window bays.
Can anyone help or come up with an alternative?
Simon
Use an octal relay to shunt the break glass's when the remote control is activated.
Fit a contact to the shutter as entry exit,put the glassbreaks on entry route????
breff Posted Today, 11:47 AM
That seems like the easiest solution, no point messing about with relays in the shutter controls, believe me you are opening a can of worms!
Mark Hawks
Ex BT Openreach Field Service
:no: never ever fit bgd's to anywhere where they have shutters..wait till fri/sat night when the drunks start kicking the shutters etc...nothing but trouble.. :blink:
fit curtain pirs in the windows..
24909[/snapback]
He said the shutter is on the inside?
Red Fox | Hosting
Affordable and Reliable UK Based Web Hosting
24909[/snapback]
24916[/snapback]
I WAS REFERING TO SHUTTERS IN GENERAL!!READ THE POST PROPERLY..
Guest simonrob
How far away from the windows have you put the gbd ?
24935[/snapback]
Peter
Approx 9 - 12 inches from the glass.
And yes, the shutter is on the inside of the door.
Simon
thats not too close..they have a good range anyway...id say its the shutter :whistle:
