Nova-Security Posted September 26, 2004 Posted September 26, 2004 Are they mounted between the shutter and the glass, if so C+K do one that ignores anything behind it, that could be a solution. How reliable they are i dont know, has anybody used these ? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Posted September 26, 2004 Posted September 26, 2004 Are they mounted between the shutter and the glass, if so C+K do one that ignores anything behind it, that could be a solution.How reliable they are i dont know, has anybody used these ? 24946[/snapback] ive used em..dont work unless its miles behind..sound has a good way of travelling..
norman Posted September 26, 2004 Posted September 26, 2004 Get some foil on!! Nothing is foolproof to a sufficiently talented fool.
Guest simonrob Posted September 27, 2004 Posted September 27, 2004 Pete The instructions state that the units should be mounted within 4.6m of the glass. There is no minimum range but needs clear line of sight and a clear view of the protected glass. I have mounted them as instructed. Don't want to put foil on the glass if at all possible. Perhaps a shunt lock would be the best option? Simon
Red Fox UK Posted September 27, 2004 Posted September 27, 2004 never ever fit bgd's to anywhere where they have shutters..wait till fri/sat night when the drunks start kicking the shutters etc...nothing but trouble.. fit curtain pirs in the windows.. 24909[/snapback] He said the shutter is on the inside? 24916[/snapback] I WAS REFERING TO SHUTTERS IN GENERAL!!READ THE POST PROPERLY.. 24917[/snapback] OY! PACK IT IN!!!! :!: Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
Guest Posted September 27, 2004 Posted September 27, 2004 never ever fit bgd's to anywhere where they have shutters..wait till fri/sat night when the drunks start kicking the shutters etc...nothing but trouble.. fit curtain pirs in the windows.. 24909[/snapback] He said the shutter is on the inside? 24916[/snapback] I WAS REFERING TO SHUTTERS IN GENERAL!!READ THE POST PROPERLY.. 24917[/snapback] OY! PACK IT IN!!!! :!: 25007[/snapback] WAZA..ill stick to alarms...if i ever need a website i'll call you....ok.. ps..id advise you NOT to give it the billy big b******s reply again...admin or not!!
Guest Posted September 27, 2004 Posted September 27, 2004 4.6 metres is alot further than 12 inch's. If the manufacture specifies that they will work from over four metres away from the glass why are you mounting them so close? Or are you trying to protect his neighboors windows as well? GBD are accustic detectors, they work by detecting sound so if you put them close to a sound source like shutters etc they will detect it. Pete 25072[/snapback] but there bay windows,so if you you put them further back they will be even closer to the shutter.go with the curtain pirs in the window...
norman Posted September 27, 2004 Posted September 27, 2004 *chants* Foil Foil Foil */chants* Nothing is foolproof to a sufficiently talented fool.
bellman Posted September 28, 2004 Posted September 28, 2004 *chants* Foil Foil Foil */chants* 25087[/snapback] Bellman Drops to knees to worship. anyway, glass breaks don't give you the chance to be "Artistic" in the same way foil does.. and foil dosn't get set off by lorries with squeaky brakes thundering past or louts smashing bottles. or rattley shutters for that matter.. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
