  • 2 weeks later...
I bought the R8 eventually. It was relatively easy to put in and replace the C&K 700L panel and keypad. Thanks for confirming the wire mapping for me. The only snag I hit was the R8 box was slightly too wide to fit in the original 700L panel, so I had to install the box on the side. Which means the battery is now in a standing up position. I guess that would be ok for a sealed lead acid battery?
  On 10/07/2014 at 13:20, db0070 said:
What's the difference between Veritas 8 and Veritas R8, other than a keypad fitted on the 8?
Nothing really. Onboard keypad or remote keypad that's it.
  On 18/07/2014 at 17:15, matthew.brough said:
Hope the engineer has steel toe capped boots on for when the battery falls
That 'engineer' will probably be me - and most certainly when the time comes, I would have forgotten the battery is out there ready to cause an injury. I better put a warning label on the front cover - but then again that could be warning to a potential intruder as well for whom sore toes are well deserved.
