effortless Posted July 17, 2014 Posted July 17, 2014 If its a late Galaxy Flex panel, have you tried the camera PIR yet [part number ISN3010B4] just got my 1st unit, so I`ll get it up on test, at least you can check before getting bashed over the head or dive bombed by the moth, similar to my neighbours home this morning around 06.45, bloody things!. Barry AFAIK the Honeywell camera PIRs only do reporting of images to ARCs for alarm verification, the consumer is unable to view the images for themselves.
GalaxyGuy Posted July 17, 2014 Author Posted July 17, 2014 AFAIK the Honeywell camera PIRs only do reporting of images to ARCs for alarm verification, the consumer is unable to view the images for themselves. Correct. A separate IP based camera system external to the property is the solution for me. I have a new in-soffit mount Axis PTZ dome ready for this. Just need to sort out the recording equipment.
aessec Posted July 23, 2014 Posted July 23, 2014 Got to wire up camera PIR`s yet but understand they are for use on free Smartphone App, so hope you are wrong about ARC only!!!!!!
GalaxyGuy Posted July 23, 2014 Author Posted July 23, 2014 Got to wire up camera PIR`s yet but understand they are for use on free Smartphone App, so hope you are wrong about ARC only!!!!!! Prepare for disappointment then. You need an PE1800IP Alarm Receiver if you want to process images. There's nothing in the app about viewing images. See doc: http://www.security.honeywell.com/uk/documents/Galaxy-Flex-Visual-Verification_Brochure.pdf Did you spend £100 on the camera PIR's ?
matthew.brough Posted July 23, 2014 Posted July 23, 2014 Got to wire up camera PIR`s yet but understand they are for use on free Smartphone App, so hope you are wrong about ARC only!!!!!! It's a visual verification pir, not spy on my gaf via a smartphone pir. www.securitywarehouse.co.uk/catalog/
al-yeti Posted July 23, 2014 Posted July 23, 2014 Ah more handcuffs only to an arc not so bad though!
aessec Posted July 24, 2014 Posted July 24, 2014 If it`s ARC only, I`ll go back to my Agility 3 or Videofied for the camera images, but back to the drawing board for the Galaxy, and yes I think the camera/pir was about £130!!
matthew.brough Posted July 24, 2014 Posted July 24, 2014 Since when did videofied allow streaming to an app? Videofied works exactly the same way as the Honeywell one does ie you need a video server that is 99% in the arc so same problem Maybe risko is your best bet (assuming the cloud isn't down again) www.securitywarehouse.co.uk/catalog/
Cubit Posted July 24, 2014 Posted July 24, 2014 Since when did videofied allow streaming to an app? Videofied works exactly the same way as the Honeywell one does ie you need a video server that is 99% in the arc so same problem Maybe risko is your best bet (assuming the cloud isn't down again) Unwarranted cheap shot.You get back to sweating that lard off on the beach.
datadiffusion Posted July 24, 2014 Posted July 24, 2014 Since when did videofied allow streaming to an app? I thought that too... So, I've decided to take my work back underground.... to stop it falling into the wrong hands
