Grade 3 Keypad
STEWENG
Does a keypad need to be in the protected/detection area to meet Grade 3?
Also, does the whole building need to be protected or can you select areas/ rooms and leave out others?
If you know the answer can you quote the spec?
Your risk assessment will answer that question
With which sentiment; how is it perceived when you have 2 office units, and a shared keypad in the communal lobby?
i.e link set lobby when the last unit closes so the keypad is then within a protected area?
On the subject of keypads and grading I'm still not sure if it's ok to display a systems status at grade 2. I know it can only be displayed for 30 secs at grade 3 but grade 2?
I only ask as I thought it was ok to display at grade 2 but the castle panel we use when defaulted to grade 2 never shows the set status.
