Cubit Posted July 22, 2014 Posted July 22, 2014 That's a fair point but I believe a professional alarm system without monitoring would be good enough, do you think differently? Leigh You're forgetting that you are being advised by a professional alarm installer,
alterEGO Posted July 22, 2014 Posted July 22, 2014 Leigh I would ask yourself how many monthly subscriptions do you have (sky etc.) ? Do any of them seem more important than a subscription that can protect your home and everything inside? Starting from around £25 per month I think it's a no brainer.
datadiffusion Posted July 22, 2014 Posted July 22, 2014 Or £2.99 a month from the £35 guy So, I've decided to take my work back underground.... to stop it falling into the wrong hands
al-yeti Posted July 22, 2014 Posted July 22, 2014 As price isn't to much of an issue ask them to price you on honeywell galaxy g2-20 , as above what do you get for 35quid ?
Leigh Graham Posted July 22, 2014 Author Posted July 22, 2014 Thanks guys points taken on-board! I fear asking someone to install a system their not used to installing could cause numerous problems, I would like someone comfortable installing them systems? Looking at the Honeywell its advised for small commercial properties? Is there a list I could refer to for installation's in my area by systems? So if I was to go for a few monitored and a few unmonitored quote's for systems what should I go for? One of the vendors said there's a power supply in the loft so was going to hard wire the main bell which seems advisable. Leigh
Alarm Protection Posted July 22, 2014 Posted July 22, 2014 With the power supply in the loft I think it's for the powermax bell but it still transmits wireless. !
Cubit Posted July 22, 2014 Posted July 22, 2014 There is an ensteemed member on here, who happens to be located in your area. Fits enforcer too had I recall.
Ronnie Posted July 22, 2014 Posted July 22, 2014 Thanks guys points taken on-board! I fear asking someone to install a system their not used to installing could cause numerous problems, I would like someone comfortable installing them systems? Looking at the Honeywell its advised for small commercial properties? Is there a list I could refer to for installation's in my area by systems? So if I was to go for a few monitored and a few unmonitored quote's for systems what should I go for? One of the vendors said there's a power supply in the loft so was going to hard wire the main bell which seems advisable. Leigh No company one will have issues with the enforcer as it's plug and play and probably the preferred panel of window fitters and plumbers alike. Although I happen to know the guys who run the local car wash prefer to fit powermax on the weekend...
Leigh Graham Posted July 22, 2014 Author Posted July 22, 2014 Yep.... no idea what you mean by the preferred panel of window fitters and plumbers, assuming you mean anyone can fit them? I had a quotation for the Enforcer should I go for that?
Cubit Posted July 22, 2014 Posted July 22, 2014 You might want to ask if the North East contingent would like the opportunity to contact you regard this. It wouldn't be right for me to name them direct but we do have active members in your area.
