SouthernStar* Posted August 10, 2014 Author Posted August 10, 2014 Thanks for the proper response... Ill most likely start out with a sensor & some contacts. Once i set up everything together, ill be putting it through a test which can give me peace of mind that it works. Im a student studying so thats the reason for my budget..
SouthernStar* Posted August 10, 2014 Author Posted August 10, 2014 I forgot to add, the main house has a alarm panel with siren & armed response, im assuming the alarm panel has a wireless receiver or not ? Damn im newb with this ....
james.wilson Posted August 11, 2014 Posted August 11, 2014 Possibly if the system is hybrid or wireless securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
SouthernStar* Posted August 11, 2014 Author Posted August 11, 2014 Thanks James, i did confirm now that the system isnt wireless & my relative got screwed over from a bad company trying to make money, so got overcharged for a outdated system. In anycase i have found out that i can wire a receiver to a zone then wire a PIR to the remote, its a 403 MHz Binary code remote but im not sure if it will reach inside the house where the receiver is sitting, if you can give me some insight about this it will be great ! Thank You Mmm... i could probably just run a wire into the roof then place the sensor closest to the outside room, that sounds like an idea.
matthew.brough Posted August 16, 2014 Posted August 16, 2014 I amnot racist... Yes you are You have it in for Burnley folk . . . www.securitywarehouse.co.uk/catalog/
