American Dynamics Utc Problem
connor2425
Hi,
I have 6 domes all running back to a Megapower LT, intellex dvr.
The domes have replaced old and are telemtry run up the coax, dome end set to 891 and LT all set to UTC, all domes running fine apart from 2 that wont go through there boot phase and have slight interference pulsing top to bottom, seem to be linked in some way.
Any ideas before I go routing through the rats best at the back of the dvr unit :-/
cheers
I have no experience with the kit, but...
Have you tried swapping a good and bad one to see if the fault follows or stays?
Yes it's the first thing I did, it's a comms prob down the coax as when I change the address the dome boots, the picture clears but obv no telem as it needs to be set at 891 for up the coax
what sort of distance are we talking to these two domes?
I have had issues in the past with other equipment when up coax.. distance quite far and signal drops when also sending telemetry signals too...
Managed to find the problem, one dome needed the termination settings changing and the other had the coax split into a monitor, removed the monitor and all good.
Thanks for the help.
cheers
