gsd Posted August 17, 2014 Posted August 17, 2014 Hi I have received a letter from edf saying that my cul de sac will be having a 12 hour power cut I am worried about the alarm battery the alarm is a scantronic 9800 with 5 pyronix magnum pir's 2 scantronic 320 pir's a cqr integra I think bell box and 2 keypads any idea how long the battery should last? Any ideas thanks
datadiffusion Posted August 17, 2014 Posted August 17, 2014 When was the system last serviced? So, I've decided to take my work back underground.... to stop it falling into the wrong hands
norman Posted August 17, 2014 Posted August 17, 2014 Not 12 hrs, get it down powered then re-commisioned once the power is reinstated. Otherwise you'll be up in the night along with your neighbours. Nothing is foolproof to a sufficiently talented fool.
gsd Posted August 17, 2014 Author Posted August 17, 2014 When was the system last serviced?7 months agoNot 12 hrs, get it down powered then re-commisioned once the power is reinstated. Otherwise you'll be up in the night along with your neighbours.ok mains and battery and disconnect battery in bell thanks
norman Posted August 17, 2014 Posted August 17, 2014 No problem, also not uncommon for the nvm chip in the 9800 to dump the programming. Nothing is foolproof to a sufficiently talented fool.
gsd Posted August 18, 2014 Author Posted August 18, 2014 Power came back on 5 minutes ago just reconnected the battery and all seems to be fine and still has programming. thanks
norman Posted August 18, 2014 Posted August 18, 2014 Pleased to hear it, thanks for the update. Nothing is foolproof to a sufficiently talented fool.
