Guest aechlin Posted September 28, 2004 Posted September 28, 2004 Hi, if I purchased a SD1+, would I need to pay a premium to BT to use this piece of kit in the avent of a signal? I am a firm believer being British, that I personally should pay a high premium to use this - but if I dont have to, I would'nt mind dealing with the let-down ) Alistair
Guest RICHL Posted September 28, 2004 Posted September 28, 2004 It will work on a normal phone line no probs, and normal call charges apply. Beware though it has a REN value of 1 so add up all your other phones on the same line, and the total should not exceed 4.
Monteey Posted September 28, 2004 Posted September 28, 2004 You might want to consider the new SD2, nice new sleak blue screen, and even tells the tempurature!! Good bit of kit, the standard all are set by. Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest aechlin Posted September 28, 2004 Posted September 28, 2004 Thanks for the replies, whats the normal call charge? a local call is it? Alistair
breff Posted September 28, 2004 Posted September 28, 2004 Texecom do a good speech/text dialler as well The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Deltaseven Posted September 28, 2004 Posted September 28, 2004 Thanks for the replies, whats the normal call charge? a local call is it?Alistair 25149[/snapback] The idea behind the speech dialler is that it phones whatever number (s) you program into it - so if you program your next-door-neighbour, it'll be a local call, if you program your mobile, it'll be a mobile call. You get the idea... D7
Monteey Posted September 28, 2004 Posted September 28, 2004 Texecom do a good speech/text dialler as well Yes, not used one yet but i hear good things about them and if their other stuff is anything to go by, should be a good'un. Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest Posted September 28, 2004 Posted September 28, 2004 Texecom do a good speech/text dialler as well Yes, not used one yet but i hear good things about them and if their other stuff is anything to go by, should be a good'un. 25159[/snapback] I've just been out to finish commisioning one today after BT have put the lines in. Decent piece of kit, the listen-in facility seems to work quite well, and it's got line seize on it.
