Alarm Protection Posted August 27, 2014 Posted August 27, 2014 Have to take my hat of to the OP asking for info on the high end equipment. Makes a change. !
imran999 Posted August 28, 2014 Author Posted August 28, 2014 Obviously you guys are used to big budget system installs. Mines will be a drop in the ocean by comparison! Ideally looking for reliability and best bang for buck. All i see on the forums is pyronix. Seems to be very popular. Is this cause its cheap or because its a decent product? So looking at the 2 way wireless systems, If i remove remote cam capability and some of the higher end of the budget systems , then i am left with Pyronix Enforcer Visonic PowerMaster Texecom Richochet Scantronic I-ON16 Galaxy G2
datadiffusion Posted August 28, 2014 Posted August 28, 2014 I-On 16 is very basic, and cannot have firmware upgraded ever. Only the 40 upwards has on board ethernet (the 30 can be upgraded but has no on board ethernet) However, its all academic as Scantronic (at the moment) is 1 way. Avoid unless you only want wireless fobs etc... and everything else is wired. So, I've decided to take my work back underground.... to stop it falling into the wrong hands
ezki1 Posted August 28, 2014 Posted August 28, 2014 what about hkc sw1070, hybrid panel, 2 way, everything could be wireless if need be, even bells and keypad. They do both wifi and gsm moduals and a app for a smartphone to set/unset. And not very expensive in my opinion.
al-yeti Posted August 28, 2014 Posted August 28, 2014 Where can he buy the hkc and all its bits? Scantronic might be best thing? What's easiest to programme?
imran999 Posted August 28, 2014 Author Posted August 28, 2014 Not fussed with the programming. As long as i have the installers manual, then i should be fine. I'm in IT and generally tech savvy. List whittled down to Pyronix Enforcer Visonic PowerMaster Texecom Richochet Galaxy G2
matthew.brough Posted August 29, 2014 Posted August 29, 2014 Would you like to control via an app? If so Texecom is your only real choice. Of not I'd be getting the list to tex or g2 www.securitywarehouse.co.uk/catalog/
Lwillis Posted August 29, 2014 Posted August 29, 2014 Id reccomend either the Enforcer or G2. The Dimension and Flex Galaxy series also have an app
matthew.brough Posted August 29, 2014 Posted August 29, 2014 The Dimension and Flex Galaxy series also have an app Didn't see those choices on his list? Risco Lightsys would be my choice. Or that www.securitywarehouse.co.uk/catalog/
