9651En Question
djrock
Hello, I have been testing a newly installed by me 9651en. I am writing a quick reference guide for it.
I have a question about unsetting it, when I enter from a Final Exit zone (entry timer starts) and let the timer expire or go on and trigger a Normal Alarm Zone the alarm goes off. When I enter the code at the keypad it asks if you want to unset so you have to press tick, if you don't it stays set.
Why does it ask you this? I would think if you start the entry timer you would want to unset it as normal? Is there a setting to change this?
Thankyou :cheers::'>
djrock
Hi, I am not sure, don't think it does areas, just Levels.
:cheers::'>
