Nvq 3 In Security Systems
a1steve
How they going to prove grandad rights
the same way a co will track your work history if they do it properly,the quals thing wont happen without grandfather rights as you will end up with too many cases in the echr for breach of working rights it works in other sectors as they have had it for years this industry hasnt so to implement overnight so to speak wont work,they have to chose a date and after that you need xyz to work in it easy to set up but some want it one way,tho something probably has to be done before it ends up not an industry at all
I did an nvq, three year course.
The cctv module was based on methods from the stone age.
so is electrical tbf,the principle doesnt change
in college they taught how to to the door wiring, cant remember the name of it when u wire a loop on a door and put a sheet or ply over it ?
cc wire or snapwire
yeah, I only came across it once so far, never fitted it not sure if people even do anymore :S
never done it for years or foil,just stick a viper on sorted....im expecting arf on soon...
Be a long wait
