BUSTER Posted December 29, 2014 Posted December 29, 2014 We have had a few problems with the last Webway Go gprs only unit we fitted last week, it locked out with network failure and wouldn't recover, had to go back to site (one hours drive away) and reset the unit on Christmas eve. It failed again yesterday but at least this time it has recovered. Webway are going to investigate, anyone else had a problem? Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
james.wilson Posted December 29, 2014 Posted December 29, 2014 Havnt used the little board yet securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Ronnie Posted December 30, 2014 Posted December 30, 2014 We have 4 or 5 of the new smaller boards, all without issues.
Belfastengineer Posted December 30, 2014 Posted December 30, 2014 We have had a few problems with the last Webway Go gprs only unit we fitted last week, it locked out with network failure and wouldn't recover, had to go back to site (one hours drive away) and reset the unit on Christmas eve. It failed again yesterday but at least this time it has recovered. Webway are going to investigate, anyone else had a problem? What signal strength were they showing when commissioned. We have had a few do this and not recovered so engineer sent to site and install high gain aerials. Problem units showing signal strength of 4 3g which isn't great
BUSTER Posted December 31, 2014 Posted December 31, 2014 I am pretty sure it was 4, spoke to Webway tech at the time and they said it shouldn't be a problem, system is now showing Texecom panel lost but I haven't received a call from the customer yet Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
Belfastengineer Posted December 31, 2014 Posted December 31, 2014 TBH with Dualcom if it goes into failure it normally restores itself but seems Webways don't like it and need a reboot to get back online. Thinking of connecting power via output and programming code as a link to reset.
al-yeti Posted December 31, 2014 Posted December 31, 2014 Thought texecom webway issues were resolved?
jimcarter Posted January 2, 2015 Posted January 2, 2015 Buster has raised a query in respect of a particular site and I have carried out some investigations this morning which I hope he does not mind I share with you. The device is configured for a Grade 3 reporting time. The decision process that marks a path "bad" can take up to 5 hours to determine that a path has failed. The recovery process is initiated by the successful delivery of recovery polls, and in a Grade 3 deployment these polls can be sometime apart. The recovery process can be speeded up by restarting the SPT which will initiate a recommission of the device. I suspect that this was the case on Christmas Eve. Why? First here is a snapshot of the radio status this morning from the SPT. You will see that the signal is poor indicated at "2" (on a scale of 1 to 10), and whilst the device has a 3G capability the device is using the 2G network. I suspect that either 3G is down or not available on this cell. 10:06:41 GSM SIM Status: Waiting Roaming SIM - Auto Reg. Status: Roaming Signal Level: 2 Cell Technology: 2G Frequency Band: 0 1: 23410 = "O2 - UK" - Available (GSM) 2: 23415 = "vodafone UK" - Current (GSM) 3: 23430 = "EE" - Available (GSM) 4: 23433 = "EE" - Available (GSM) 5: 23420 = "" - Available (GSM) ------------------------------------ Looking at the history over the past two weeks, the signal quality has been especially poor. Whilst signal is not significant in a 3G environment, it is in 2G operation. You can see that the signal has never been above 3 during this period and both data and GSM registration has been lost on occasion. Recommendations in a situation like this:- Single path radio does not appear suitable at this location, even with the longer reporting time of G3 An alternate path would be desirable (Broadband primary or PSTN backup) Antenna placement - HG antenna with external installation In reference to the Texecom, the protocol requires the SPT to inform the panel of a loss of all communication. The SPT has completed this function correctly in this instance. I expect this will continue as long as the signal quality remains poor, the likelihood is that further disruptions in signalling are likely. Kevin (Belfast) - Looking at your sites, they are all Grade 2; so this would certainly explain the longer recovery times and a reboot would have the same effect as I mention above. Jim Carter WebWayOne Ltd www.webwayone.co.uk
9651 Posted January 2, 2015 Posted January 2, 2015 So have one that i'm going to put on a bench panel to try the udl this coming week. Connection wise, how do they interface with GD, and will they interface with G2 in anyway yet for UDL?
jimcarter Posted January 2, 2015 Posted January 2, 2015 Are you asking me about the Honeywell? If yes then the following applies: GD - Connect to Bus 1 (must be bus 1), using A, B terminals on SPT and the corresponding on the Galaxy. Comms Mod 4 in menu 56, emulating an Ethernet module at SIA III. Set your trigger events - make sure set/unset (option10) is turned on and same applies for Zone restores (option 18). Make sure in Alarm reporting you have one gateway address entered (can be anything, loopback address of 127.0.0.1 will do) and an Account Number. As long as the Galaxy has something in these then you will be fine. Remote Access should be turned on with access at anytime. With the G2 (yes we support UDL), you wire & programme the same but there is a quirk in that the G2 has an option for Hardware Priority, this needs to be set for an Ethernet module. Programming guides can be found on our website and I am sure I loaded as download here at some point. For RSS connectivity you will need our Remote Manager S/W, PM me and I'll sort that out Monday. Any problems, get in touch. If you comment was not for me....ignore all that. JC Jim Carter WebWayOne Ltd www.webwayone.co.uk
