Powermaster 30 G2 Install Code Reset
diyman207
Hi. I changed the install and config codes a while ago for a powermaster 30 G2 panel, and I cannot remember them. Is there a way to reset them? I guess a full factory reset is an option, but I have seen elsewhere in these forums that for the power max, shorting 2 particular pins does the job.
Hi, unfortunately and for obvious reasons we are unable to give out defaulting codes or information.
That's one of the problems that you get with a diy installation, the level of support can be non existent when you need really need it. The perceived benefit of DIY over Professional install is generally one of cost, but one of the main benefits is that support is a available 24/7 365 days a year.
