Interface A Securilite Voltek 1804 Pir With A Gjd Sapphire 1500 Mk3 Controller
aissecur
Hi, I have a customer who has a single GJD opal pir going to a GJD Sapphire 1500 Mk3 triggering external LED lighting..
The customer has procured a voltek 1804 PIR..
My question is,  can i also interface the voltek into the GJD controller as well as using the exisitng GJD opal pir?
The wiring to the Opal is 4 cores -
12v / 0V DC (2 cores),   Trigger (A)  -  single core trigger input into controller for detection & one as a photocell input (S)
The Voltek is much the same as the above with S - trigger input   L -Photocell or light level
If i was to rely on the Opal to control the light level into the controller (to allow relay switching of the LED lights during darkness)
Do you think the S input from the Voltek PIR  would work with the GJD controller & trigger the LED lights (When the Opal PIR had signalled darkness)
Thanks in advance
Nick (aissecur)
Hi, Many Thanks for the reply...
Good point.. I just need to find out what the GJD Opal detector outputs when in alarm... Im almost sure its  0V in alarm.. I will get the mutlimeter out when im next on the site.
A relay is a good idea.
If not using a relay i would have to check what the opal outputs when in non alarm state, as if its not 12v i fear the introduction of a Voltek pir with 12v flowing in non alarmed state may cause some internal damge to the GJD controller..
Thanks Nick
