Scantronic 9651 With Pyronix Deltabell
rsrfire
As above may need an eng reset, that's an option for sure, but also the message won't just clear by itself.
You'll need to enter your user code and acknowledge the fault, IF its user reset it should then reset IF the fault is clear.
