tst Posted September 10, 2014 Posted September 10, 2014 Hi all, I have an ADT system which was installed when I moved in by the previous owner 4 years ago. The display is now showing adt bat mis 0001 and also manager reset code required. I do have that code but I don't know what to do? I have read that it's most probably the battery that needs replacing. Can anyone please advise and if it is battery, where can I buy replacement from? Thanks
al-yeti Posted September 10, 2014 Posted September 10, 2014 Having taken over lots of adt systems , adt are famous for this ,cans you may cause more problems just replacing the battery , better to get someone even if it's a one off to check the charging circuit ie quick service , doesn't cost allot really
goncall Posted September 10, 2014 Posted September 10, 2014 Having taken over lots of adt systems , adt are famous for this ,cans you may cause more problems just replacing the battery , better to get someone even if it's a one off to check the charging circuit ie quick service , doesn't cost allot really famous for what
norman Posted September 11, 2014 Posted September 11, 2014 Famous for not replacing batteries on non maintained systems lol Nothing is foolproof to a sufficiently talented fool.
datadiffusion Posted September 11, 2014 Posted September 11, 2014 The crooks, they should be on watchdog... So, I've decided to take my work back underground.... to stop it falling into the wrong hands
matthew.brough Posted September 11, 2014 Posted September 11, 2014 The crooks, they should be on watchdog... They were if I remember correctly for dialling premium rate numbers www.securitywarehouse.co.uk/catalog/
datadiffusion Posted September 11, 2014 Posted September 11, 2014 Ah right! So, I've decided to take my work back underground.... to stop it falling into the wrong hands
matthew.brough Posted September 11, 2014 Posted September 11, 2014 www.securitywarehouse.co.uk/catalog/
norman Posted September 11, 2014 Posted September 11, 2014 I can't remember that? Nothing is foolproof to a sufficiently talented fool.
morph Posted September 11, 2014 Posted September 11, 2014 They were if I remember correctly for dialling premium rate numbers Bit like phoning your firm mat out of hours!
