Honeywell Ade Lcd Accenta Question
hundleton1
Hi all I'm new here, i have worked in the industry for years but never did to much with honeywell alarms, i was a cctv installer for 11 years, mostly stuck to AV and CCTV,
i have a Honeywell Accenta allarm to install on my parents house next week, all looks straight forward apart from iv read the manual and the 3 programs are confusing me slightly, i understand program 1 is everything, then program 2 Timed states it should be entry route and P3 will delay if an entry route is triggered first but if not will go off instantly.
my question is i take it P1 uses P2 zones for entry/exit delay as i could not see how to specify specific zones as entry/exit?
also I'm looking a setting up one program that just protects  the Garage via a PIR,
its gong to have 4 PIR's
1 Kitchen (this will be entry/exit point)
1 x Hall
1 x Back room
1 x Garage
My Plan was
P1 everything
P2 Kitchen PIR
P3 Garage PIR on its own.
hopefully this would allow P3 to protect the garage only ?
thanks in advance for any help
All points can do different things in the different programmes.
For P3, make all zones unused bar the garage, enable the setting option to either timed or instant. Job done.
